Tech-2 calib.
  • Thread starter Thread starter maxm
M
maxm
Hi...
The DIC on my -97 is only showing 12,8 volts. The generator leavs 14,6 volts to the battery. c4c5 mentioned something abaut
Tech-2 calibration a wile agao.
Had the car at a GM schop but they never heard of it. So....
How is it done or were can i read abaut in the manual.
Max
I have limited acsess to a Tech-2.
Hi there,
First, you set up the vehicle. 97, Corvette.
Then, you go into 'BODY"
Then, 'INSTRUMENT PANEL CLUSTER'.
Then, 'SPECIAL FUNCTIONS'
Then, GAUGE RECALIBRATION
Then follow the instructions.
You may have slightly different instructions for the European versions, however, this is how it is done in the US.
Allthebest, c4c5:hb
c4c5...thanx...i will do that and let you all know.
Max
Now i have done it. It was easy to follow the instruktions.
c4c5 thanx...you ARE the best.
Max
Hi c4c5....is it possible to calibrate the spedo in the same way ??
I forgot to look in the Tech-2.
Max
OK..then i know. It is a handy little thing that Tech-2
Max
