M
magelin
Temperature Sending Unit vs Sender In Head
I have a 1970 LT-1 and the Temp Gauge does not move it is stuck at under 120. I wanted to check and see if the sending unit was the problem and the only thing I found was bolted into the passenger side of the block and it looked like the Temp Sender In Head not the typical temp sending unit.
Willcox Corvette, Inc. - Parts, Restoration, Help - "When you're not the biggest, You try harder"
Where would the Sending Unit be?
