vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
Well I tore her apart today and found the following.. She was clean and recently rebuilt I'm guessing about less tham 5K ago ( running miles )
Any additional insight on parts ID's would be helpful..here we go...
Block casting
3858174
64-67 Camaro
327 small journal
2 bolt
Crank
Mains 2.29
Rod 1.98
4577 Forged
Con Rods GM markings but ???
30 on top of piston (I'm assuming 30 over)
Pistons single relief for valves, flat top, Looks cast an SJ in an oval symbol on inside of piston
Pins pressed into rod
Con rod nuts have little slits 1/2 way down
Heads
Double Hump
64 cc
3782461
No acc bolt holes in head
Big straight plugs
Drivers side
175 ( Jan 7th 1965)
Passinger?s side
1275 ( Dec 7th 1965)
Application
62-66 Camaro/Corvette/Truck/Chevy II
Valve size
2.02 Face
1.60 Face
No overlap ( so I?m guessing next size down..it?s the seat area measurement right?)
Small press stud ( aircraft lockdown nuts)
Double spring
Cam unknown ( looks like big lift..have to measure need bits from work for that)
On back of stick c400 p
C-400-P specs as follows:
> Duration @ .050: 222 Int / 222 Exh
> Advertised Duration: 290 Int / 290 Exh
> Cam Lift: .298 Int / .298 Exh
> Gross Valve Lift: .447 Int / .447 Exh
> Center Line C/L: 110 Int / 118 Exh
Other cam markings cast CWC C3 EP1
GM timing gear Double gear chain drive
Number on gear face 3735412
Crank gear had 3 positions It was set @ 0
Edlebrock TM ?1 intake
Spacer/adaptor plate for carter
Carter Carb AFB competetion series
9605S-2794
Stock distrib
Had orig Potatoe masher oil seperator in back of lifter valley.
At this point I could just have everything hot tanked & checked re painted & resealed and off I go.
the block has allen screws in the cam lube points ( I'm guessing top end oil restriction)
The front of the timing cover has 2 HUGH plumbing type caps in the block..it looks factory.
Mike
Block casting
3858174
64-67 Camaro
327 small journal
2 bolt
Crank
Mains 2.29
Rod 1.98
4577 Forged
Heads
Double Hump
64 cc
3782461
Big straight plugs
Drivers side
175 ( Jan 7th 1965)
Passinger?s side
Application
Valve size
2.02 Face
1.60 Face
Double spring
9605S-2794
Stock distrib
Mike
