O
Outlaw
As I am doing a Complete Rebuild of my 1984 Corvette 350 ci Engine and will be doing away with the CrossFire and installing an Edelbrock C-26 Dual Quad Intake with (2) Edelbrock 500 cfm Carbs and also doing away with the Computer, I have found some heads that I believe will work (Thanks to JonM's recommendations) to install Aluminum Heads instead of having a Valve Job done to the old Cast Iron Heads...
My Question is, will the Following Heads work with my 1984 Corvette 350 ci Engine:
This is a complete pair of GM Hi-Pro Corvette aluminum cylinder heads. Ideal for small-block Chevrolet V-8 hot rod's, fresh water power boats and other high performance aplications. Casting number 10088113. This set of heads features screw in studs, 1.94" and 1.50 valves, 58cc combustion chambers, advanced D-shaped exhaust ports (enhances flow of burned gases) and centraly located spark plug holes to improve combustion efficiency, and HO 350 Corvette design springs. Heads have been completly professionaly rebuilt here at our shop. This set of heads does not have an intake manifold heat riser or EGR passages. The exhaust ports are .100" higher than production cast. Spark plug holes are angled and require 3/4" reach gasketed spark plugs (A/C spark plug number AC FR5LS). Heads are machined with accesory holes for power steering, alternator and A/C mounting. This set of heads does require the later model center pull down valve covers. GM suggests using a composition head gasket with stainless steel fire rings is recomended to prevent galvanic action between a cast iron block and aluminum heads. Help your hot rod loose 50 pounds by installing these heads.
I need to know something before these get gone and I DO NOT wish to buy these Aluminum Heads if they are not going to work on my 350...
Thanks in advance...
mike
