I needed to pull one more interior molding part out of the car that I hadn't done before because the newly painted pieces were now no longer going to match the finish.
This is the molding piece that runs directly over the windshield and also has the rear view mirror and the sunvisors screwed thru.
As I was removing the screws one of them turned about 1.5 turns than the head broke right off on me leaving the rest of the screw in the screw hole. It's sticking out just enough to try and grab it with something but not enough to get a really good grip on it. I tried vise grips but it's not enough to hold it securely. It seems like it will turn back IN, but it also seems to want to stop like it gets bound up turning OUT which of course is what I need. BTW, it's stuck in there because of rust as you can see in the pic.
As i'm sure you know that's a pretty small screw and it screws right into the top rail of the birdcage. Obviously I need to get that sucker out of there or else I can't re-attach the left side sunvisor back up.
I can't see trying to drill it out for two reasons: one, the remaining part of the screw is pretty small in diameter to try to get at it with a powered handdrill, and two, it's right by the windshield and one slip and i'll hit the windshield and probably crack it.
Bob (Stepinwolf) was kind enough (Thanks Bob!! ) to offer some excellent suggestions last night after I emailed him in a bit of a panic. Two of his three suggestions were somewhat feasible for me to try and attempt. (Bob, you know the last suggestion that involves cutting out that section and than afterwards re-welding it back in is way beyond MY abilities! )
Anyway, I now have a couple of ideas to work on to get that sucker out of there so now we get to see just how well I can handle working on the car when things don't go as smooth as planned.........
I know things like this are par for the course when working on old cars, but geez, who would have thunk something as simple as taking out a molding screw would cause such a hassle.
See, as always, leave it to me to make the simplest things into something complicated!
ad
