- Thread starter
- #21
He said that he checked the line bore, and he said it was fine considering there was only 400 miles on the motor.kingkeith427 said:If your rebuilder has not checked the line bore of your main bearings he is doing a bad job. If it is not line bored it will wear your bearings unevenly and lead to premature failure of the bearings. FIND A NEW REBUILDER THAT DOES EVERYTHING HIMSELF ONSITE.
The person that is rebuilding it now is not the same place that rebuilt it the first two times. This guy was highly recomended by the Corvette shop that had pulled my motor and put it back in, this is where he sends all of his motors to my understanding.vettered91 said:Vettefan87,
I agree with Hib's post. After two fails of your engine with these guy, maybe it is time to look out for another mechanic and check everything step by step.
You can get some clues here, but I think it's going to be the rebuilder the one to do the evaluation and get the job done. I really don't trust the one you have now.
Good luck and keep us posted!
George.![]()
The shop the guy sent it out to, that he sends all of his crankshafts said it was fine, and I did not need a new one.rrubel said:I think Hib gave you a pointer with this sentence:
"It is possible you've got a bad crankshaft, and I'd check it for straightness and journal size but I'd also be looking at the block's main bearing bores. I'd be looking for a problem with the oil passages in the block."
[RICHR]
