dannykelley
just got 2002 conv.....no info on driver door and not specified in manual or spec sheet....looking for correct tire pressure
I am sitting here wondering how many sets of tires that fool has at max pressure?
I'll bet that 50 psi is the maximum air pressure for the tire, not recommended tire pressure.
You would be right, but I wasn't going to argue with him. You can't win an argument with a fool.
Me too!. If I hadn't stepped out to watch him do the actual alignment, I'd worry about it too. But I talked to him about the specs I wanted and he set them right to where I asked. So I guess he knows about alignments.
Scarey that he didn't know about the sticker on the door. Amazing how quickly a fool or idiot will drag you down to their level.
I change my oil until the garage (the floor) gets too cold; then I have it changed. I went on the premise anyone can change oil, check washer fluid and air pressure. Wrong, as they put ~35 in which caused the rear tires to "bounce" when accelerating in first.
Oh, he knew about it. Told me that was for "factory tires that came with the car, and the sidewall said the same thing........" , YEA, ok.
Maintain Inflation Pressure At The Recommended Level
This level is recommended by the vehicle manufacturer and is shown on the vehicle placard or in your vehicle's owner's manual.
Maintaining proper inflation pressure is the single most important thing you can do to promote tire durability and prolong tread life.
Underinflation is the leading cause of tire failure and may result in severe cracking, component separation, or "blowout." It reduces tire load capacity, allows excessive sidewall flexing, and increases rolling resistance, resulting in heat and mechanical damage. Over inflation increases stiffness, which may deteriorate ride, and generate unwanted vibration. Over inflation also increases the chances of impact damage.
Tire Care & Maintenance Guide | Goodyear Tires
