semperfih2o
Active member
I have lost the ability to turn off the traction control.I was driving and "traction control disabled" was showing. I hit the button a couple of times and the squiggly tire marks went away. A hundred miles down the road i felt the need to disable the traction control but no dice. The car is a 2000 coupe with A4 and other than the infamous "turn signal problem" has been a dream for 40k miles.
I pulled the codes and got a B2597H which relates to traction control.
Is there a known problem with the switch or a relay?
As always this forum is a plethora of knowledge regarding C-5s.
Thank you for your help.
2LOWUFO
2LOWUFO
