Mr. 350
- Joined
- Apr 28, 2016
- Messages
- 10
- Location
- Avondale, AZ
- Corvette
- 1969 Cortez Silver Convertible; 2003 50th Coupe
1969 Corvette, 350 cu.in., Muncie 4 speed
I have spent the last 15 months rebuilding this car literally bumper to bumper. I have rebuilt 2 or 3 other engines before this one and helped with others but transmissions are out of my league. The trans worked fine before I removed the side cover to replace the leaky gasket. I had trouble getting the forks back in and when I let out the clutch the gears do not engage. I can moved the gear shift through the gears but it stumbles. The clutch and clutch peddle seems to work OK. The Muncie is the later version and the pin in the side cover CANNOT fall out. I installed a new flywheel, new roller pilot bushing, and new clutch disc. I reinstalled the same Zoom pressure plate I replaced several years ago. If I can't find a solution I'll have to pull the trans, rent a truck, and take it to a transmission shop. I hope someone out there has a solution. Thanks in advance.
