well, the saga continues.
you may remember about a week or so ago I posted about how I took my '65 in to my mechanic to get the distributor rebuilt, the timing set, and basically just get her running correctly.
After getting all the parts from LICS and having him rebuild the distributor and doing everything he wasn't able to get the timing set correctly and told me the balancer slipped (this was already the 3rd time he had the car in to try to get it running right) and I needed to get a new balancer and he would install that and that should fix it. Since I now had spent almost $800 in parts and his labor over the 3 shop visits I lost confidence in him and got recommendations for another mechanic in my area. Everyone from my Vette club ALL recommended I see another guy not too far away. He loves working on these old cars and is an ex-racer. I figured OK, i'll give this guy a shot.
Dropped the car off Mon. night and picked it up this afternoon. He SUPPOSEABLY checked the distributor, the timing, the advance, and confirmed proper TDC. Also adjusted the valves - there were too tight.He said the bolt on the balancer was also loose.
He replaced the points in the distributor which just been replaced 2 weeks ago, replaced the sparkplugs because he said they were the wrong type.
After all this the car runs worst now than it did before I dropped it off to him!!!! It still breaks up over 5500RPM and when I let off the gas the idle now won't fall below 1100rpm most of the time. When it does drop below 1100rpm at idle it takes a long time for it to do it than it feels like it want to stall out and I have to keep goosing the gas to keep her running.
I'm really getting p***ed off now!!! why can't I find someone to get this car to run right. I'm now into this issue for approx $1100 and it's getting worst instead of better.
Sorry, I know i'm venting here but i'm too the point of such frustration that I just don't know what to do.
last time I posted about this everyone gave me great advice on how to fix it but the problem is I can't do the work myself.
I've wanted this car since I was 12 and it was a lifelong dream to finally get her but even with the short time I've had her I've had such bad luck I'm almost ready to throw in the towel. I know the idiot backing into me requiring repairs was just an accident and the paint blistering on the hood at a show was a novice mistake, but if I can't find somebody who can do what should be a relatively basic repair job, what am I to do if the car ever needed a major motor repair?
Is it really too much to ask to correctly set up a distributor, get the timing set, and set the carb to make the car run smooth? (sorry - venting here again!)
ad
I think I need to buy a punching bag for days like this
![martini :m :m](/data/assets/smilies/martini5.gif)
