U joint change
W
Willycool
Hello everyone!
I just changed the u joints on my 89 C-4.......made a big difference in performance . But what a job!
I would get a strange shutter at 90mph and the odd clunking noise when i put it into gear.
What was happening was that the left shaft was very loose (bad u joints) and it was causing the car to shutter as it truned.
I suggest that you use the DANA u joints for a replacement.(sealed unit)
The greaseable u joints tend to collect grit, which will cause damage to the unit. (non sealed)
Good Luck!
Thanks, Willycool!
Need to change the u-joint on the upper left outdrive? shaft
soon and I appreciate the encouragement!
