geogolf
i had been having trouble with high idle, would not throw any codes and did not do it all the time. hard to find problem removed tb and found gasket was cracked where air passages were, made new gasket seemed to fix wrong finally put another ecm on that was prob. idles around 7/800 now, in gear 5/600 couple of members said they had same thing if you can swap ecm that might do the trick. thanks to everyone who helped geo. ps was looking at seat controls, and they look like they are burned under buttons is that a common thing. or should i check it out thought maybe prob. was to much weight when you move seat any help appr.
