W
wes
Does anyone know how to measure the omhs on a vats key pellet?
Thanks WES;help
Thanks WES;help
here is a paragraph from the link i provided. i understood it. how was it the wrong generation VATS info as stated in your email to me?
" How to determine the Value of your key:
By chance you may know what VATS key you now have. Most people do not. There are basically two ways to determine what VATS key you have. Remember, there are 15 differrent possibilities. First, your key can be "read" in a VATS tester. Most locksmiths have these readers, and don’t change anything to tell you. There is another way for you to read the key value yourself. If you have a Volt Meter you can test the OHMS (resistance value) of the chip yourself. Just set your Volt meter to check OHMS, take each lead and place it on each side of the "chip" on your key. A number will appear. Take that number on your volt meter and apply it to the OHMS chart below. Keep in mind that it may not be exact. Just pick the closest value to your reading. "
Thank You this was very helpfullhere is a paragraph from the link i provided. i understood it. how was it the wrong generation VATS info as stated in your email to me?
Junk man I love your imformation & How to doe's I love the one the running lights. keep up the great work
