J
Joe D
I have an "intermittant" (aren't they the worst?) vibration problem in my 1966 roadster. The most intermittant vibration occurrs at higher speeds, aproximately above 50 mph. It feels like a high frequency or shuttering in the floor area because I can feel it in my feet. I have balanced and changed the tires three times (new radials), installed a fiberglass leaf spring, sensa-trac gas shocks, ball joints, trailing arm bushings, wheel bearings, etc.
Everything seems tight and as it should be. I even had the drive shaft balanced.
The second vibration is more consistant with hard acceleration. The car seems to shake from side to side more with more acceleration.
None of these are in any way severe but seem to be more of a nusance than anything else. The car is top-notch (NCRS Top Flight) otherwise. Any other suggestions?
