I hope someone has some ideas about my brakes. My brakes have been flawless up until a few months ago, when The Noise began. The left front brake makes this annoying grinding sound when I come to a complete stop, and when I wash the car, for instance when the rotor and pads get wet, there is a horrible groaning sound; it only makes this loud groaning sound when the pad is wet, after I drive for awhile the sound slowly disappears. I've never had this problem before. At first I thought it was a stuck caliper, so I changed out the caliper, the problem didn't go away. Then I figured it was time for new rotors and pads anyway so I changed them out as well (tirerack.com). New caliper, new rotor, new pads, and the sound is still there. Can't be the master cylinder or the brake booster, because then all the brakes would make the same sound. Flushed the brake lines AGAIN, sound is still there. I'm at my wit's end.
Can caliper mounting brackets bend? If so, that might explain it. Could it be a bad wheel bearing? The bearing seems fine. Didn't hit any potholes that I recall. Anyone have any ideas? TIA.
