S
ssvett
Yep, Still on the silver 69. The mechanical guage reads 180 all the time(a little higher after shut off). The original guage reads 250 shortly after starting. The car is not hot!!!!!!This original guage reading has been tested with 2 guages and 3 sending units.
The car is not hot!!!!!!!I checked the continuity of the gnd, and the temp sending unit wire and the voltage. All seem to be normal. The resistance on the Temp sending unit wire raises as the car gets warm(as it should)I'm not sure though how high the resistance should be?????But it is the same on both units????????I'm sooo confused.
.....BTW, just a small bit of information for those of you at home, wait for the car to cool down before attempting to change the sending unit........That stuff is hot.........even at 180 or so........I bet I won't try that again for awhile
..............Steve
