Thanks guys. Hib, I am going to use the valve springs that came with the kit. Ralph, does that length seem right for the pushrods? So, I need to purchase Comp's engine oild additive?
Jeff,
This is a link to the pushrods I used:
http://store.summitracing.com/partdetail.asp?part=SUM-G6400100&autoview=sku
Okay for the prep for the cam installation...
Go to your local GM dealer and pick up a quart of
GM EOS Assembly Lube. Also, get a tube of moly lube.
When removing the old cam, remember to remove the fuel pump. The fuel pushrod can prevent removal of the old cam.... also, when re-installing the fuel pump, you can hold the push rod in place by replacing the 3/8 bolt with a longer bolt (on the block in front of the fuel pump) - just be sure to put the short bolt back into place before turning the engine!
Now for the oil... be sure to drain the old oil and replace with oil that has a high
zinc content (you MUST be sure that the oil used for the cam break-in contains high amounts of zinc) -- be sure to change your filter too, of course. I used 20W-50 VR1 Valvoline Racing oil (Advance Auto). I did not use a synthetic oil as I understand these are not a good choice for the break-in because synthetics are too slick and do NOT allow enough friction --- which is critical for the break-in and mating between the lifters/camshaft.
Since you are not doing an entire rebuild or changing the oil pump, you do not need to worry about priming.
When installing your new cam, you should coat each lobe with the EOS assembly lube, and copious amounts of moly lube. After all items were in place, I poured the EOS assembly lube directly over the cam, lifters, etc. (this is good stuff).
The initial start-up and proper break-in period is critical... lots of folks have ruined their brand new cam by not allowing a proper break-in.
There are slight variations of the process, but they're mostly the same... just don't start/stop the engine, and don't let it run at normal idle for the first 30 minutes. For my initial start-up, I kept the idle fast at approx 1500 RPMs. I then kept it running for about 30 minutes, varying the idle between 1500-3000 RPMs. Also, remember that you may need to add more coolant after startup, because the water jackets will likely need to be filled... happened to me, and almost overheated!
Follow these steps and you should be a happy-camper.
Ralph
