eoseitz01
Hi everyone. I'm working on my first engine build and managed to break a time sprocket bolt off in my cam. Luckily I have a new cam and was wondering if it would be a good match.
I have an 1981 LT9 block bored .30 over with a pair of 202 camel hump heads. I have stock length hardened steel push rods and 1.6 comp cam roller rockers. The head gasket is an advance auto felpro blue strip gasket. I'm not sure on the thickness. The lifters are most like stock. I don't have details on those. The Pistons appear to be flat top.
The cam I'm wanting to put in is an Erson e110421.
The specs are below.
SBC Performance hydraulic cam
-296*, 228*@0.50, .472 lift High Flow 1H
Would this be compatible with my build? I'm wanting to run pump gas and I'm concerned I may not be able to with this cam.
Thanks.
Sent from my iPhone using Tapatalk
Thanks.
