zeke2u
New member
My '03 Z06 had a tree limb fall on the roof and windshield. The frame was bent very slightly along the top, almost midway between the two cast aluminum corners. I'd like to just cut-out the damaged piece at both corners and weld a "salvaged" extruded aluminum frame between the two cast corners. My question is which modules, besides the battery, should I disconnect before welding the windshield frame? Is it only the air-bags I should be concerned with, or should I disconnect the PCM, too?
