ltmark
Re: my 85' coupe. It has been off the road for 3 years while my wife whooped breast cancer. I just recently started going through it to fix some problems, including rough idle and overheating that my wife was experiencing just before we took it off the road.
I've now have the plenum and TPI all apart to clean, etc. Even though I replaced the EGR about 4 years ago (only 1 year of which it was being driven) I took the opportunity to check the EGR's function with my vacuum gun and low and behold, the diaphram didn't budge and would not hold ANY vacuum. I started doing some research and discovered that I had been given the "Canadian" model.
The FSM says that no egr will cause engine overheating and poor SMog test results.
Does anyone know what the difference would be in US vs. canadian EGR valves. I would think that even in Canada, the diaphram would have to move with vacuum with similar vacuum levels? The only visible difference is the actual valve that allows the exhaust gas by it extends down into the manifold about 1/2 inch on the US model and the Canadian one was level with the EGR valve base.
The correct US one that I just ordered is 65.00 The Canadian one that I got was 90.00? I guess Auto Zone put the double whammy on me?
I'm hoping my overheating will be solved when it's all back together!
...so now you have time to get back to "servicing the mistress", eh?
