Indy Z06
New member
I need a little help with an intermitent electrical problem. It started with the Traction Control System Warning light. Decided to bring it to the dealer and have them check it out. I started the car, the HVAC controls went blank like a fuse had blown, and the ABS warning light came on. I checked every fuse in the car and all were fine. I started it back up to head to the dealer and had the Check Engine Warning light added to the list. About half way to the dealer I hit a bump in the road, the HAVC came on and all but the Check Engine lights went out. The TCS light is back on now with the Check Engine light but everything else is fine.
My guess is that there's a loose connection/ground somewhere in the mix. The obvious quesitons, at least for me, are what do these things have in common and where should I start looking?
I appreciate any help I can get.
