Ok, -
I really dont see any logic in that statement, I changed my therm to a 160, I put in a switch for manual control of the fans. Its been 2 years now and my 95 has always run between 175 and 200. Even with both fans on with the 195 therm the temp would not get much cooler, as the therm would close and cycle. The simple logic is that the cooling system is quite adequate to run at much cooler temps, however emission control issues overide design calibrations, like only using the fans at extreems.
Actually in the later model C4 Corvette all you need is a $3 switch and some light guage wire. The cooling system is just not using its full potential ,See my webpage-
As for 160 being to cold-
Putting in a 160 therm does not mean running with coolent temps of 160, just like having a 195 does not mean never getting hotter than 195., like the cycling between 195 and 235.
Using a lower temp therm and a manual fan control will allow extended operation between 180 and 210. The engine oil will still get hot enough to boil off condensation, as oil usually runs hotter than coolent. Additionally the benifit of having the ATF fluid run much cooler that under stock conditions will extend service life of the unit. Another benifit of cooler operation via a lower temp therm and manual fan control are greatly decreased under hood temps, extending the life of any hoses or lines.
Since I have made these small modifications to my 95, I have experianced slightly lower fuel consumption and a gain of 2 tenths in the quarter. (180 launch temp vs 215, average idle temp after waiting for a pass) On days below about 75 the engine will run rich if the coolent temp is held below 200.
Poor cooling system condition will always cause higher operating temps, however the stock cooling system is not operating up to its full potential in stock form. (195 therm, ECM controlled fan)
Regardless of what you do...you will not lower the temp until you change the capacity of the system. Even adding different cooling media, ie...water wetter, only has a minimal effect. All of this is just plain ole logic....
. If you have a 180º thermostat and you engine operaters at 220 changing to a 160 degree thermostat wont change your temprature one bit, you need more radiator, more air flow or both to reduce operating temperautre.
