Antenna information
Please be advised that the whole antenna assembly is about $140 through GM and is readily available.
Access is through the inner fender skirt, after you remove the left rear wheel. Also, please remove the inside trim panel from the cargo area, as this hides the grommet, and harness coming inside the car, from behind the left outside tail lamp.
You will need a 10mm and this should be fine.
REMEMBER, A CLEAN GROUND SOURCE IS CRITICAL TO NOISE FREE OPERATION OF THE ANTENNA.
You will see 2 grounding straps for this installation, use them both, and make sure you mount it in the same location as the old one. Also, lightly remove the corrosion from the bolt down point.
After you are finished, you can use some battery terminal protector spray to protect the area from further corrosion.
Best to all ,c4c5
