M
MotuVette
There are 5 pot metal legs protruding through the door panel that are cast as part of the trim for the inside door handle latch pull. GM placed a washer over each post and peened/flattened them down to secure the trim to the panel. I pried off the washers and removed the trim. Although I was carefull not to shorten the legs there isn't enough material protruding to re-secure them onto my new panels as GM had done.
Any hints will be appreciated.
