80' HEI Distributor, where is the tach lead?
3GenMuncie4
Findlay, Ohio
1980 Yellow Coupe
I have a 1980 coupe with HEI ignition and there is a white wire with connector on the end of it coming from the negative side of the distributor, which is where the tach plugs in, but there I can't see another wire that would connect to it.
Where is the tach lead located that comes out of the firewall?
Just got my Vette and its a fixer-upper, so any help would be appriciated.
email: PyroManiac350@hotmail.com
Evolution1980
Administrator
Cleveland, Ohio
ZZ4, 700R4, Steeroids rack & pinion, VB&P Brakes
Hey 3GenMuncie4, welcome to the :CAC
I don't know the answer to your question, but within the next couple of days, possibly even today, someone will chime in with the answer!
Be sure to stop over in the new member introductions forum and introduce yourself! Since your car is a fixer-upper, you'll likely be in these forums a lot asking questions and getting solid answers. The CAC is in my opinion (and I may be a weee bit biased) the best place for getting knowledgeable and friendly answers to all things Corvette.
Again, WELCOME!!! :beer
wishuwerehere82
Rochester, NY
Red '82 Coupe,Sebring Silver '98 Coupe
On my 82 there is a ballast resistor bolted on the intake manifold that couples the tach lead from the distributor to the wiring harness to the dashboard. If that's any help.
Twin_Turbo
Enschede, The Netherlands
1982 Twin Turbocharged Red/Black
that's a capacitor, a signal filter, not a ballast resistor.
