Seat Rail bolts
Thanks for the replies....I realize I was not clear in my original posting. I am referring to the seat rail bolts...the ones on the driver's side that are attached to the seat rails. These go through holes in the floor and are secured with large captured nuts....at least this is what my 81 has??
The bolts are so stripped that after the first 1/4" they bolts diameter reduces...for most of the remained of the length. The nuts have nothing to thread onto. It appears that for some reason there was movement that caused these bolts to wear down. I tried re-threading them, but the die would almost slip past this area. The nuts would start fine but when they hit this reduced area, the would bind and start chewing up again.
I was able to press out the front bolts in the seat frames just using my vise and a socket. HOWEVER, the rear two were a completely different story. For these two I had to heat the bolts to red hot and then drive them out. Something was holding them in...could not see any signs of welding...looked like there was some type of glue or something....whatever, finally got them out.
I do not understand why the driver's side has bolts attached to the seat rails, whereas the passenger side has none...bolts just pass through the holes and thread into nuts attached to the floor pan. Why the difference??
I got some M8x1.25-25mm 10.9 bolts and flat washers to replace them with, was not able to find anykind of exact replacement. I may epoxy the bolts to the rails or I may just leave them loose. Makes putting them in a bit difficult as I need to hold the bolt head on the inside and also turn the nut under the car which is why I may epoxy them in. Not the same as whatever was used at the factory....man those were a PITA to get out.
On to the next project.
Lanny
