oklahoma1
I have a 93 Ruby LT1-Automatic. The car has 73000 mi. I have replaced the WaterPump & seal, Optispark & sea, Balacer Hub & sea. I do not see any oil pan peaks or Intake leaks or valve cover(It is not wet in these areas ). The oil leak seems to be coming from the right front of the engine and leaks down the right side of the cross member. Is there any other source for this leak on the fron of the engine (Sending units etc) Any guidance is appreciated.
