3dale1
Hopefully a simple one, guys....
I replaced the drier this weekend, and am recharging the system. Have lost 3 cans of 134 due to a major leak out of the hose/pipe fitting coming out of the drier going toward the firewall. Fitting on the drier is tight, not cross threaded, and doesn't appear to be cracked or kinked.:W
My question is this: Does that end of the pipe use an o-ring as it screws into the drier, or is it just flared? I have tried an o-ring which came in a little bag with the drier, which seems to be the right fit, and have also tried it without the o-ring, leaks equally bad both ways. I see that the other end (the one with the big platic nut) uses an o-ring. Hate to keep buying cans of 134 at $8 each till I know what is going on. :W :W :W
TIA, Joe
TIA, Joe
