EOLIVER
- Joined
- Dec 14, 2003
- Messages
- 116
- Location
- SAN DIEGO, CA
- Corvette
- 1989 DARK BLU METALIC SIX SPEED CONV
I have a 1989 with six speed and AFR 1041 heads. I'm ready to either ebuild or replace the engine. I have a budget of 5-6K and wondering if I should simply rebuild my current engine or pruchase a should purchase a ZZ4 or 383 shortblock and use an after market intake? Does the 383 require a computer chip change. Will the ZZ4 short block bolt up to the AFR heads and accept all the other L98 TPI topside parts?. My car currently has the following aftermarket parts:
- AFR 1041 L98 Heads
-Open Air Lid w K&N filter
-MAT sensor relocation
-bbk 52mm TB
-Adujustable Fuel Pressure regulator
-Hypertech coil and distributor cap and rotor
-flowmaster delta 40 mufflers
-high flow cat
-accell fuel injectors
What other CA members do?
-bbk 52mm TB
-high flow cat
