Red69
Thanks Art, It seems 'bracket racing' was the buzz word that automatically dictated their level 3 recommendetion.
What stall TC are you using?
Glen, you are helpful by admitting your limitation and suggesting alternative sources. Seek and ye shall find!Glensgages said:Red 69:
..... looks-like you've found some informative guys to help with your A/OD install.....
many of the guys here can point you in the correct direction, and might be a bit-more 'friendlier' than that 'other' site.
Yup...ya always seem to get better answers when everyone parks their ego.
Sorry I couldn't help you any-more with your 700-R4/200-4r questions.....![]()
[Inspector #2211 Harry Callahan, "Magnum Force" ]Red69 said:..... you are helpful by admitting your limitation.....
I just downloaded the instructions for installing my 700R-4 and I have a feeling I may be asking for help too! There are 20 pages and they say about 20 times that if they aren't followed exactly that the transmission will burn up and they won't warranty it. It's a little intimidating to say the least! :eek
I told Red 69 when we started speaking that I had no 'real' hands-on knowledge of these A/OD aftermerket transmission (I do some bracket-racing with THM400s ), but it sure sounds-like BTO is very-strict about how you install their products, giving themselves plenty of lee-way to say "I-told-you-so" and walk-away if something goes-wrong.....Art Jett said:I just downloaded the instructions for installing my 700R-4 and I have a feeling I may be asking for help too! There are 20 pages and they say about 20 times that if they aren't followed exactly that the transmission will burn up and they won't warranty it. It's a little intimidating to say the least! :eek
Art,Glensgages said:I told Red 69 when we started speaking that I had no 'real' hands-on knowledge of these A/OD aftermerket transmission (I do some bracket-racing with THM400s ), but it sure sounds-like BTO is very-strict about how you install their products, giving themselves plenty of lee-way to say "I-told-you-so" and walk-away if something goes-wrong.....
:ugh
The only wiring that I'm aware is INSIDE the pan is the wiring for the lock up solenoid. Everything else should be external. I don't know what you'd need to be doing inside the pan...??? Maybe the instructions are slightly different for the older C3's, but I doubt it. The transmission itself doesn't change, so.... ???Art Jett said:They kept mentioning removing the pan to make adjustments. How many times did you have to do this? It is not an easy task unless one has a lift! Also, they have a section on the lock-up wiring. I understood from the sales info that the wiring was supposed to be complete inside the pan and all that was required of the customer was to do the external wiring? It is going to be a real PITA to break everything in as I have a new motor and transmission. Oh well, it's all fun and games, right?
I hope to swap a THM400 into my '82 in the next few weeks/months, and I understand the 700-R4 cross-member needs to be changed as-well:Evolution1980 said:..... I'm a little salty towards BTO for their 'post purchase' customer support/satisfaction.....
I'm not sure if the crossmembers are the same for a 350 and a 400, but someone else here will know.That's me, that's me! (...unfortunately...)Glensgages said:I've heard on-line about them (even from people who LIKE their products )
Evolution1980 said:.... I believe that BTO requires the inline filter for the first 500 miles (which is just a good idea, requried or not)...
That brings-up another question that I have:Art Jett said:I have the one that came out of my 77 with a TH350 that I'm not going to use. If you can use it I would be willing to part with it. I wish I would have known you were going to do the switch earlier. I bought a crossmember from an 82 w/ a 700R-4 for my installation. If you are interested, PM me and we can work out a deal for the piece and shipping to your location.I'm not sure if the crossmembers are the same for a 350 and a 400, but someone else here will know.
Unfortunately, you ain't the only-one, Evo.....Evolution1980 said:That's me, that's me! (...unfortunately...)
That's a good idea. Better than the magnetized plug by itself. I'll probably disassemble an old computer harddrive and grab the 'rare earth' magnet out of it. Them puppies are strong! Maybe one on the oil pan and bottom of the oil filter too! :LGerryLP said:I placed a strong magnet in the oil pan to prevent spreading metal shavings around the system in betwen fluid changes.
Nope, they are NOT interchangeable.Glensgages said:That brings-up another question that I have:
are cross-members from the earlier, THM350/TM400 equipped C3s interchangeable with latter 700-R4 cars (i.e. - are the frames the same, that they will physically 'fit', or does THAT even have to be modified )?
I probably wasn't clear-enough on my earlier post:Evolution1980 said:Nope, they are NOT interchangeable.
200R4, existing crossmember is OK.
700R4 requires custom crossmember due to longer tailshaft / mounting point on the trans...
ad
