coptertom
Hey Guys,
After four months in the garage I finally got my 81 back to my hanger.......Just had ingition wires, plugs, true dual (left cats off), hooker headers, new S/S brake lines, calipers, rotors, power brake booster, master cyl, rebuilt carb (stock) and to top it off.............a new paint job!
Just have a couple of questions that maybe you guys can help with.
First: Brakes...........they certainly work a lot better than they did. I notice however that when I put the vette into gear and take my foot off of the brake...........the vette just sits there. You have to give it gas to get it to move (almost as though the pads are snug to the rotors. The mechanic mentioned that the emergency brake was not working and that the pads on the emergency brake needed to be repaired.
Would that have anything to do with the brakes feeling as though they were tight? Or is it just that since I have a whole new brake system, that the brakes just need to be broken in.
Second: I had the carb rebuilt and new wires and plugs. The carb seems to be loading up with gas and the check engine light came on. When I disconnected the electrical sensor on the carb (stock), the check engine light went off and the vette seemed to run smoother. It still loaded up, but not as much as when it was connected.
Any ideas? I know that I am asking a lot with out much info to go on...........but hopefully it is a start to try and figure out what is wrong.
