So HOW DID IT WORK
EXCELLENT! I still had a half a gallon of the dot 5 so I stayed with it.I used less then 3/4's of a quart to bleed the entire car encluding flushing .I replaced the rear brake lines and hose's.
My fault but I chipped my paint with the quick connectors.I connected the unit,tested as per there instructions,Filled it up with fluid,pumped it up to 10 psi MAX and then just went to the furthest port and just slowey bled untill I got clean clear fluid.
This was too easey to do.I had my son watch the pressure gauge and he had to only pump it once. THis realley was a very simple process and I recomend the unit to others.I purchased the magnum unit because I wanted the larger size (figuring the useual use a 1/2 gallon for a bleed) and I wanted the quick connect's(the ones that scratched my car) Any ways I paid 99.00 plus shipping.
With connecting the unit.testing the unit,using the unit,then disconecting the unit and putting it away it took me less the 20 minute to do an entire bleed.(keep in mind the car was allready up on a lift and the rear tires were off.
The only thing I made a slight mess was disconecting the adapter
Below is my son watching the gauge for me .
I also went out and purchased 2- 18" lenghts of 3/16 clear tubing to make this project easyer
