gedmeyer
Looking at my alternator last night, I realized that bubba worked on it before I owned it. The brown wire to the 2-prong connector is fine, but the red wire to the connector is connected directly to the red post on the back of the alternator. A yellow battery wire is also connected to the post on the back of the alternator. I also noticed that there is a cut red wire coming from the T-fitting on the wiriing harness running along the drivers side fender of the car.
Am I correct that the cut red wire is supposed to be connected to the pronged connector of the alternator instead of the second prong being connected directly to the alternator post? The cut wire shows +12V right now, so it is still connected to the battery. I feel like the current wiring setup is fooling the alternator because it's reading the output directly from itself?
-gedmeyer
-gedmeyer
