dhewett
New member
I have a 2015 coupe which makes a bumping noise and vibration when the car is moving slowly either forward or reverse and when turning either left or right. It seems like it is bumping at a rate of about 2 times in one wheel revaluation. A friend has a 2014 doing the same thing.
I talked to the service manager and he says it is just the nature of the beast and it is being caused because the tires are so wide and causing them to slide sideways when turned sharply. I told him that I would have to sleep on that and think about it. I have and I don't!
Did I hear that this car has variable speed steering? Could this be the culprit when turning lock to lock? I don't really understand how VSS works.
Thanks for your thoughts,
Don
Don
