J
joe paco
bought two bushing kits and replaced the broken/granular bushings in my '91 headlights today. one was making racket, but I changed both, a smart move. I did not get the gears, based on other people's experience, and it was a good decision. I have to wonder about the wisdom of spending $60 for a bronze gear, when the bushings apparently fail before the plastic gear. the gears were like new, even viewing with a magnifying eyepiece.
I followed the instructions from several threads here, removing the assemblies from the hood - a 5 minute job at the most- except that my parts came with slightly different instructions, like loosening the two #6 screws from motor to gearbox, to facilitate removing/reinstalling the drive gear to worm gear. one motor screw broke, and I had to drill a new hole and use a drill point screw, which worked fine. any self threading #6 would do, if you even needed it. the one screw was holding ok.
both motors came with 4 washers, but both were in different locations -either 3 under the shaft bearing in gear housing, 1 on top of the gear, or just the opposite. not sure if these are used to set height of gear or what. probably are not critical. ("critical" and plastic don't go together.)
as usual, the engineers designed the assembly such that at least one screw is inaccessible, the bottom motor mounting screw, but the bracket under it can be loosened enough to get access. the drift pin is easy to remove and install, and you simply turn the manual dial to spin the drive shaft so it aligns with the counterweight to reassemble.
compared to changing spark plugs, this is 80% easier.
of course, the headlights work "perfectly." (Corvette and "perfectly" don't go together, either.)
saludos, joe
saludos, joe
