S
studiog
I have spent a couple of hours trying to remove the ignition switch from my 61 dash with no luck. I have read a thread about how to do it by John McGraw and Larry (IH2LOSE) but I have a few questions.
http://www.corvetteactioncenter.com/forums/showthread.php?t=56252&highlight=ignition+key+removal
When you insert the paper clip in the lock should you feel any spring tension or something releasing? Which direction should I be turning the switch with the paper clip in, and should it unthread or should it just pop out? Thanks for any help.
