Larry Shermak
I've run into some trouble re-assembling the rear suspension, specifically when I tried to bring the rebound straps around the axle back up thru the bracket. I have installed new springs, mounted the rear axle to the springs and installed the radius rods. This is when I found out I was in trouble. It seems like everything would be in a bind if I got it together. I'm thinking about taking the U-bolts off & raising the axle till I can attach the rebound straps then rastling the springs back to where I can attach the U-bolts. Any thoughts?
I know studio & 61 silver may have done this recently. Help!!!
