C1 trans/driveshaft tunnel scatter shield?
  • Thread starter Thread starter studiog
S
studiog
Does anyone know if there is such a thing as a C1 trans/driveshaft tunnel scatter shield that was stock? I thought I had seen something about it a few years back but I can't remember where. I hate to even think of the damage to the fiberglass (and occupants) if the driveshaft let go. I have brand new u joints but any additional protection would bring peace of mind. :confused
Re:
I know there's a shield on the floor in case the flywheel decided to... well... fly. But, I have never seen any info on a shield for the driveshaft.
Just my 2 cents..
Jim
PS: seeing your member photo next to mine makes me chuckle every time...
There should be a piece of steel plate rivoted to the underside of the tunnel just above the front universal. If memory serves me correctly, it is about 8" front to back, bent in a "U" shape to match the underside of the tunnel and maybe 3/16" thick. I also believe it is in the AIM if you look hard enough.
Yes of course the AIM...I will check it out. Thanks for the reminder.
Propeller shaft guard
Found it! It's called a guard assy and the part# is 3728417. In the AIM see sect 4 sheet 2.
