Chuck540MZ
Hi guys,
I'm totally new here and as the subject line reads, I know almost nothing about C2 Corvettes. I have a couple of BMW's that I play with a lot, but I've always wanted a mid-sixties Vette. I have a line on one that's available from a friend, so before I go leap into this arena I have several questions, so please bear with me.
This particular Vette is a 1965 Coupe with the 327/350HP engine and 62,000 miles. The numbers do not match since the engine was replaced and the color is bright yellow, not the factory yellow which I really don't like anyway. I can hear everyone scream "RUN" already.
The car had the so-called "Frame-up Restoration" 3 years ago and to my untrained eye, it looks to be in excellent shape. It has factory side pipes, 4-speed, air, leather and the knock-off wheels, which apparently can be traced through the car's serial number, so everything is "correct" for the car. My friend spent some more dough to replace one of the disc brakes, wiper motors and wiring harness and to his knowledge there is only one problem with the car- vapour lock when it's hot. He tells be that a re-routing of the fuel line and/or adding an electrical cooling fan should fix the problem, but he's not sure. Otherwise, the car runs great and has lots of power.
I do not plan on buying this car (or any other car) for investment purposes, because I want to drive it daily for about 3 months a year, so the "numbers-matching" deal isn't a big deal, IF the price is right. My friend is asking about $45K US, which may or may not be high, but I take some comfort in the following:
1) The car is already up here in Canada where C2's are very hard to find in good shape.
2) My friend is fairly well off, so anything that needed to be fixed was, other than the vapour lock problem.
3) As "numbers matching" perfect C2's go up in value, they have to drag the second tier cars up with them in value, since they aren't making 1965 Corvettes any more.
4) I love the car.
So, finally, the questions:
1) How's the price?
2) What are the main things to watch out for? Website to refer to?
3) If this isn't the car, how easy is it to buy a similar one elsewhere?
4) Anything else?
Thanks for your input.
4) I love the car.
1) How's the price?
4) Anything else?
