With my 340 to 360 HP it showing mid 13"s so if you want 10's you looking at some big bucks to get that fast.
If I remeber correctly you have a 4 speed man in the car I had that set up in my old 1982 TA but it had a carb I use to beat on that car blew the rearend but the trans held up, lot of burnouts, dounuts, power drifting with that car.
The guy next door has 700 HP in his 1990 C4 with a 6 speed so far it holding up for him.
As for Auto the 700R4 they say can hold 650 to 700HP if built up for it then the 4L60E they say is stonger it cost me ($1000.00) for my 700r4 most places cost about $1400.00 on up with convertor I looked into the E-Bay stuff more I looked into them Stay away from them.
As for convertor how much stall do you need LOL I think 1984 to 1986 have a 2000 RPM stall convertor 1987 and on I think they are 1800 or 1600 stall with my engine mods I using a 2200 stall I was looking at a 2400 but the trans guy said it mite be too much for what I what the car for a every day street car with my motor combo.
My Vett is in the trans shop Now I had them rebuild mine but it would not shift It was a carry in job after I installed in the car.
I just put the car on a tralior a towed it down to the shop try to do this with a E-Bay trans that out of state.
I using a 700r4 with all the good hard parts inside HD clucth packs and a shift kit they say it good for 500HP.
The 700r4 and the 4L60E are overdrive Auto's Stock motor I was getting 22 to 25 MPG now the motor is breaths better makes more power more easly I dont have to give as much gas to keep the same speed up do to It's TQ motor I get more like 30 MPG as long as you keep you foot out of it If on the gas all the time you going to sucking the gas.
You hear Honda Car Ect getting 34 MPG but it a Honda car you driving a V8 Corvette.
I dont plan to drive the car hard but will hold up when needed.
Like I said I in the 340 to 360 HP range and around 427 TQ they say TQ what will fry the trans but TQ puts you in the seat and gives you the rush.
I also looked in to Full syn trans fluid ATF but Pete K a man thaty knows what up more or less said yes Full Sny make your Clucth plates last longer but harder on the hard parts so I much rather buy a soft part rebuild kit than a hard and soft rebuild kit and change the trans fuild out every 30000 miles the trans should last you with NON syn ATF.
Rearend gears work great but to low will make you run out of motor quickly these motors stock die around 4600 to 4800 RPM's.
My setup shouild be good for 5200 RPM's
To have the rearend regeared is about $1200.00+ for the ring and pinoin set including labor if you change the carrior out that more cash but if you going to do the rearend might as well have the posi rebuilt at the sametime extra $200.00 or so.
They have online places that swap out you core rearend core for there's but you have to pay for the new rearend ($1400.00) Plus core charge anouther ($1400.00) if you rear end they say it's good then they will refund your core charge back to you.
I have 307 gears in mine for the motor setup I think they are just right good lowend power and still can drive up on the HWY 2000 RPM'S at 70 MPH.
If you go with 373 you most likly be at 2500 RPM'S at 70 MPH 410 grears 3000 RPM's you get the idea more it revs more gas if you have a cam that made for High RPM's mite be a good thing like the guy next door and his 700 HP C4.
Low gears will get off the line faster if you can keep the tire from going up in smoke but hurt up on the HWY you lose topend speed also.
I like the twisties also as is HWY intechanges on ramps every now and then geting on it hard but not all the time.
I also looked into going with full coilover shocks for the money I just going to get a set of Adj Koni shocks as for tires full sticky tires are great but I don't need them I much rather have tires that last 50000 miles instead changing tires out every 20000 if you lucky at $200 to $300 per tire.
Be smart build your self a fun street car you can enjoy everyday that will not cost you every penny you make to keep on the road and keep on putting tires on it every 6 months.
Marv, I know what you mean, honestly in my mind I use to want an extremely fast car capable of 200, but after I thought about it a bit, I'd much rather have a 10 sec 1/4 mile car that tops at 120 or 140, just sounds smarter, plus, if I set my gearing ratios closer together like that, then it should actually help my mpg a little as I can keep my rpm's lower by shifting more often. However, that's not my expectations for this car (anymore, haha).
I used a program I found on the internet, just to see what it said my car would do as far as drag timings, and, I was fairly happy with the results whether or not they are going to be very true.
It said with 205 flywheel hp (which I assume the hp rating on it was flywheel) for a 3300 lb car (I guessed at the weight) that it should be:
1/8: 9.91 sec @ 69.7 mph
1/4: 15.46 sec @ 87.1 mph
I know those aren't fantastic times, and I'm sure my '01 Chevrolet Cavalier might be able to pull out better times, but it's what I expected. And it at least gives me a starting point.
If I did decide to change the transmission to be able to withstand a beating of 300 hp, should I find another automatic, or should I change it to manual. (I love manual to death but I don't know if I want to go through all those changes and cutting holes and junk)
If so, what transmission should I get?
Again, I'm not shooting for 300 hp, but I just want to make sure it'll withstand any amount of stress I put on it
