eboch
Hi;
I recently changed the clutch in my '05 Z51 changed (to a Z06 clutch). As part of this, the shifter & linkage get partrially taken apart. This all worked out really well as far as the clutch is concerned. However, I now have a bit of trouble shifting into first (either at a stand still or slow roll)
It feels a bit like the linkage is blocking/binding or not quite "aligned". There is no noise or grinding. If I move the shifter across the center of the shift pattern, or engage another gear, it then usually allows me go into first afterward.
There is a shifter adjustment on the shifter base, can this have an effect on the shifter engagement/operation? if yes ... any tips on how to make these adjustments ... or any other possible shifter/linkage adjustments?
Does anyone know of any "wear" items in the linkage that might need replacement?
eboch
eboch
