ameribrit
Amazing what can happen to all plastic car. I have a 34000 mile 96 CE LT4 Corvette, never had accident, perfect condition, garaged undercover most of the time. I noticed that the center vent was loose and discovered that the vent had come out of the threaded connectors -they had completely broken up! The threaded inserts are integrated into more plastic that makes of a large chunk of the dash.
1. How can I repair/replace these cheap threaded connectors to I can reattach the vent? Plastic breaks and there must be a way to do this, rather than replacing the entire dash substructure of an automobile. There must be some repair method for this.
2. How can this happen, cheap/bad ABS plastic? The center vent appears to have warped outwards to some extent, but not sure since I don't know what they look like new, never had it out. I would think the engineers would use material that would not warp in the stream of cold and hot air.
I will put up a photo as soon as I can so you can see what the problem is, I am not sure if I described properly.
Any ideas would be greatly appreciated because dealer is no help and this insane problem is making me want to sell the darn thing. otfl
Thanks!
Thanks!
