IrishJoker
- Joined
- Sep 21, 2004
- Messages
- 79
- Location
- Baltimore, MD
- Corvette
- 81 Gray Coupe, 95 Yellow Coupe, 02 Torch Red
I've got a problem with my carberator choke not dropping off after warm-up. The darn thing idles around 1500rmp and then drops back to 1000rpm. I can manually go on to the passenger side and knock it off the step but as soon as I press the gas pedal is jumps back up to 1000rpm after warm up. Normal idle during the summer is 800rpm. What can I do with this electronically controlled carberator? Also I have two wires that I have noticed laying on in the intake manifold - one dark green and one light green does anyone know what these are for? Once upon a time I think someone referred to one of them as some sort of test lead? I've got this piece of metal sticking out from the choke that looks like one of the wires could slip onto it, is this the case? I figured the choke had to get it's electric power from somewhere?
Probably as you can tell I'm not to swift on the electronically controlled carberators - give me the mechanical one any day - but I got what I got with this 81 and I'd like it to run right.
