chevyaddict
Well, I'm stumped... and I've never, for the life of me having chevies, regardless of how long they've sat, ever had a clogged brake line. But that "appears" to be what is going on with the passenger side front. I've just replaced the caliper thinking that was the problem (it was leaking too so no biggy), but even with the new caliper I'm not getting any brake fluid out the bleeder valve nor out of the brake hose itself to the passenger side. I've got the system under pressure and nada. And, of COURSE, I can't get the &^$#@!#$ brake lines off; already stripped those stupid little fittings to try to run some pressurized air through that line.
UUUUUUUUGGGGGGGGHHHHHHHH!!!!!!!!!!
I just want to drive the darn thing!!!!!
So, have any of you had this problem? Can it be something else? I can't imagine what. Its not the proportioning valve because I get plenty of normal pressure to the driver's side front and the rear tires. perhaps it could be that little "T" where it splits off from the proportioning valve main line to each front side.... anyone have any thoughts???
