jimmers
Coming home today I got a weird grinding sound when I would push the clutch in to change gears. The shifter would also shake a bit. The noise would go away as soon as I let the clutch out. I got home and went through every gear on the driveway a few times. It only did it 3 times. I can shift without any issues, and the clutch pedal works as it should.
I tried it again about an hour later but it didn't happen. I drove the car around the block a few times and it was fine. Any ideas what is wrong? The clutch and tob was replaced 2 years ago.
