Peer81
Hello everybody,
I'm just goofing around with number and calculating different engine setups. I read a couple of books to understand everything better and on the net are also a lot of thing to find on the subjects but still I have a question on Dynamic compression versus Quench. What would you sacrifice?
I know I can always change the camshaft, gasket thickness but to make it simple for me just this comparison.
350 engine with:
72cc iron heads with 0.045 quench thickness gives me a Static compression 8.92:1 and dynamic 7.55:1
same engine (same cam) but with:
64cc iron heads with 0.067 quench thickness give me a Static compression 9.67:1 and dynamic 8.17:1
So the question is what is more important the 0.6 compression increase or a better quench thickness? Thanks,
Greetings Peter
350 engine with:
Greetings Peter
