vett boy
What I recommend is a layer of 3/4 gold nuggets,about foot thick.They allow for good drainage.Also note because of the high density winter plowing has little or no effect.
Pseudomind said:I would suggest to lay a complete drive out of gravel or whatever you use, and then come back and remove about one inch down the center and sodding that in with grass. That way when driven over the wheel trails will not tend to squish towards the center.
vett boy said:What I recommend is a layer of 3/4 gold nuggets,about foot thick.
67heaven said:I'm assuming that the local municipality will be very fussy about how I get the garage waste hooked into the septic.
arcticvette said:for your potable water; if submersible pump you can tee in near your well instead of poking a hole through your foundation(opens up opportunity for a headache). determine depth of water line by looking down well and dig carefully( locate phone, hydro, gas lines) run a 1" polyeurathane line to your garage for good volume. go with a 3/4" main hot and cold and tee off in 1/2" to your fixtures. always best to check with your municipal codes for the sewer connection. it shouldn't be a problem as long as you can maintain grade from garage to septic tank inlet.
otfl67HEAVEN said:On the issue of driveway material, Tom's suggestion about GrassyPavers really got me thinking and researching.
Here's a video from a competitor's website that shows the installation process. http://www.invisiblestructures.com/Med&tech/video/GP2GV2Video.htm
I really like this idea.
otfl
MM-C5 said:All BS aside, these are both great environmentally friendly ideas.
Oops! I forgot to add that to the estimate! But I think it still makes more sense than running a 100' line.67HEAVEN said:And, when I get this composter, from the Envirolet people, for all our food waste, I'll have a legitmate come-back for all those tree-huggers complaining about my 502 engine. :gap
Life is good.![]()
otfl67HEAVEN said:Thanks arcticvette. I'd be interested in hearing more about your idea of teeing in near the well for potable water. Just where would you actually tee in? On the existing line to the house coming off the well?
As for waste, I wonder if this wouldn't be the answer rather than running a hundred feet underground from the garage to join into the septic system?
http://www.envirolet.ca/enmulsys1011.html
No drain required!
Comments? No, not the locker room comments.otfl
