MM-C5
- Joined
- Jun 30, 2003
- Messages
- 393
- Location
- 28.0 N x 82.77W
- Corvette
- 2013 Cyber Grey Grand Sport Coupe
That's great advice Mike. Your mention of the pressure tank made me think about HOT water. There are a number of "On Demand" hot water systems that would work without having the hassel of a conventional hot water tank.arcticvette said:I would tee in to the line going from the well to the house providing that the pump is in the well otherwise that line would be a suction line for the pump if it is in the house. you can tee in where ever is going to be closest to your garage. once inside garage I would install a pressure tank to give you storage and also to reduce pressure loss in your house.
I like the waterless toilets have installed one before although not as nice as the one you've shown. But what about your shower and sink? you can get small one-piece septic holding tanks that would be dedicated to your shop, that aren't too bad for price. this system would have to be pumped out once or twice a year depending on how much water you run. if you're on septic system already you should be getting that tank pumped out once a year anyway.
hope this helps Mike
Btw, you should bid this job. I'll bet Ole Bob would even let you stay in the big house. :L
otfl
