- Thread starter
- #21
Villain
Pegasus said:If you are going to synch your fob (or a new fob) you need to be in the "fob learn" mode on the DIC. Needless to say you need the ignition on with engine not running. Check your owner's manual. It will give you the rundown. It may just turn out to be a bad fob and time for a new one.
I took my fob in to be tested and it is working. I guess the next step is to go back to the manual for a relearn. I'll let you know if it worked.
