A
AUSSIEVETTEMAN
Ok, here is the list of new parts and still I have a vibration in the driveline.
I am thinking if it is not the trans mount, then it must be the harmonic balance of the fresh engine. There is a vibration at 110 km/h or 2700 rpm. the vibration is there at the same rpm regardless of the speed, but only from 90 km/h and up. When you do higher speeds, say 160 km/h the vibration comes in and out depending on the engine rpm.
When you hold the car in drive (auto) and apply gas the rear sits down under the torque as it is supposed to and the vibration comes in and shutters the steering wheel.
The vibration seems to come from the trans tunnel.
1 New aftermarket steel rallye wheels and tyres - BF's 255/60/15 - all stud balanced
2 New trailing arm bearings and seals
3 New Rear suspension bushings - Graphite Poly (no difference noticed in ride, handles like it is on rails) (Trailing arm, strut rods and new Koni shocks)
4 New Diff carrier bushings - Graphite Poly
5 New Diff yoke bearings and seals - new LSD keepers
6 New universal joints in the input and half shafts and all have been balanced
7 Rebuilt T350 Trans
8 New trans mount
9 New balanced engine + 20 thou over, roller rockers, LT1 Corvette valve springs, new cam, high volume oil pump.
10 New engine mounts
The only other thing I can think of is the front seal is starting to leak a small amount of oil. I have bad feeling the vibration is engine harmonics.
What do you guys think?
I have spent $25000.00 Aussie dollars on the driveline and don't expect any vibration after spending that kind of cash.
ad
Probably the smallest part causing the head ache.
Cheers
Tony
8 New trans mount
![martini :m :m](/data/assets/smilies/martini5.gif)
Cheers
Tony
